Discussion topic: Changing braodband company password help
This message was authored by: puppy1955
Changing broadband company next week looking  on how to change the old password to the new one.
cant find how to do this for the Sky + Box/ planner under the network section
Any help will be great
Thank you
Re: Changing braodband company password help
From very distant memory, I believe one of the coloured buttons in the box's Network menu allows you to Reset your settings. You can then change the settings to those of your new router.
Or just press the WPS buttons on your Sky box and your router and they should connect automatically.
On your Sky+ remote press services then go to settings > network, scroll down and press the red button to reset it.
