Discussion topic: Cannot get capital letters on Sky + hd remote
This message was authored by Crystal236 This message was authored by: Crystal236
Hi I have tried pressing the buttons scrolling through but capital letters do not come up.
This message was authored by SKY1992bf This message was authored by: SKY1992bf
Re: Cannot get capital letters on Sky + hd remote
@Crystal236  Why do you need caps, in any event I don't believe sky + remotes allow for this
Please note: I am just a sky customer not a employee - posts from sky employees are clearly marked as such
Crystal236
In case I need to put WI-FI Password in manually
@Crystal236  I see your point but I don't think it's possible unless anyone else knows away round
@caesarome @Mark39 @Annie+UK  any ideas or advice on this one?
So when you cycle through a, b and c what happens as you should see the small letters followed by the uppercase ones ?
@caesarome  Even for myself scrolling through pressing number 2 on my remote only gives lower cases letters (this is when using the search option and box not connected to the web)?
Crystal236
No I've tried that and no capitals.
it's so I can connect sky+hd box to Wirelessly, I have ordered a Wireless WI FI Connector box
and so I'm hoping I won't need to input password.
thank you for your comments though.
This message was authored by Mark39 This message was authored by: Mark39
You should be able connect via WPS.
Crystal236
I'm hoping pressing WPS on router will do it. My box is so old there's no WPS on it.
There's a WPS button on the Wireless Connector (assuming it's a Sky one).
Crystal236
Yes it is a Sky one so fingers crossed.
thanks again
On average, new discussions are replied to by our users within 100 minutes
