Discussion topic: Cables SKY TV
This message was authored by: Kerrymc23
Cables SKY TV
Hi could I possibly request longer cables from the wall to my TV as this is impacting the connection! Thank you
Re: Cables SKY TV
Not unless you have Sky Protect Insurance, if you don't then you'll need to do the work yourself or employ a 3rd party as Sky Plus is now obsolete
Re: Cables SKY TV
Do you have a wall plate and connect your box to the wall plate using fly leads?
Re: Cables SKY TV
@Kerrymc23 you can buy purpose designed satellite cable extension kits from many hardware stores or online. They simply screw onto your existing cables. Just look for a kit with the size of extension you need.
