Discussion topic: Cables Rotting
This message was authored by: Rosie9889
Cables Rotting
My Sky+ is working but about 20 feet of the outer casing of the outside cabling has dried out and dropped off. How do I get this sorted.
Re: Cables Rotting
Unless you have Sky Protect insurance (Domestic & General) you will have to get a local company to replace the cabling
Please note: Free (advert supported) Hayu content is available via the On Demand section of your Sky planner, you DO NOT access the free content via the Hayu app!
Re: Cables Rotting
Unfortunately you'll need to get a local independent satellite installer to sort it out for you. Sky are no longer sending engineers for Sky+ services.
Or you could upgrade to Sky Q - the cabling and dish will be inspected and repaired where necessary at no additi0nal cost, as part of the installation.
Avatar for Rosie9889
Re: Cables Rotting
I do have Sky protect. Have phoned them and they cannot come until the 12th Nov. Hopefully it will all keep working until then
