Discussion topic: Box still initialising
This message was authored by: Spud40
Second day unable to use sky as stated box is initialising
Re: Box still initialising
Assuming you have tried powering it off at the wall for a few minutes and restarting, if it still doesn't work then it may be that the box is end of life and cannot be revived. If this is the case then there's little you can do other than switch to Sky Q or Sky Stream. Sky+ is now a discontinued legacy product which Sky no longer supports.
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
I am NeurodivergentMy Sky FAQs: Stream Glass Go Plus
The 'initialising' message is shown because the box hasn't received a viable satellite signal for while, hence the advice in @Annie+UK's post. The box itself is unlikely to be faulty. Much more likely to be an issue with your dish setup.
