Discussion topic: Box fault
This message was authored by stephen1963 This message was authored by: stephen1963
Box fault
Have two sky boxes on downstairs in living room one in bedroom,  one downstairs has a signal, one upstairs has no signal, i know sky like to blame the weather, but wouldn`t the weather disrupt both?
This message was authored by Annie+UK This message was authored by: Annie+UK
Re: Box fault
The weather could have damaged the cables to one box but not the other
Annie( I am Neurodivergent ) - Sky Plus FAQ - Sky Stream FAQ
Re: Box fault
Is the cabling connected firmly into your upstairs box ?
stephen1963
Re: Box fault
Everything is connected as should be, followed all the steps set out by sky,
This message was authored by oj01 This message was authored by: oj01
Re: Box fault
@stephen1963 You could try swapping the two boxes around to pinpoint whether it's the box or the cabling.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
stephen1963
Re: Box fault
IT was definitley the box, working this morning, don`t understand how the weather can distrupt one box but not the other?, both use same dish
This message was authored by Mark39 This message was authored by: Mark39
Re: Box fault
If the affected box isn't receiving a satellite signal on any channel, but the other one is ok, it's unlikely to be an alignment issue. It may or may not be weather related.
As previously posted, it could be a problem with the cabling to the affected box, or a faulty LNB, or the  box itself. Swapping the boxes is a good suggestion as it will narrow down the possibilities.
Re: Box fault
Each box has separate cables and separate sockets on the LNB there are several things that can affect a box connected to a dish without affecting all boxes
On average, new discussions are replied to by our users within 100 minutes
