Discussion topic: Additional Sky box for different room
Message posted on 12 Aug 2023 08:19 PM
I have a Sky+ HD kit, and a Freesat set up. Am I able to buy an additional Sky box to use in a different room? If so, who do I contact?
Message posted on 12 Aug 2023 08:24 PM
Re: Additional Sky box for different room
Sky don't offer multiscreen for Sky+ customers any more
Message posted on 12 Aug 2023 08:28 PM
Thanks Annie. What do you suggest I do?
Message posted on 12 Aug 2023 08:29 PM
You could see if you can get a deal for a Sky Q upgrade
Message posted on 12 Aug 2023 08:31 PM
@Mo There's not a lot you can do other than to switch to sky Q if you want multiple rooms
Message posted on 12 Aug 2023 08:33 PM
Would I still get Freesat with Sky Q?
Message posted on 12 Aug 2023 08:36 PM
@Mo You would need the sky essentials package which is around the £15-25pm mark
Message posted on 12 Aug 2023 08:43 PM
I don't suppose there is a direct line to someone at Sky to speak about switching to Sky Q?
Message posted on 12 Aug 2023 08:56 PM
@Mo There is no direct line all calls are routed through the automated system
Message posted on 13 Aug 2023 09:58 AM
@Mo You can call on 150 from a Sky Talk Line or Sky Mobile.
(UK) https://www.sky.com/help/home Scroll down and click on ‘Need more help’ and it provides a 0333 number
(ROI) on the same link change the flag in the very bottom corner to the ROI flag to obtain an 0818 number.
Stay on the line and don’t hang up if prompted to. Apparently the quieter times to ring are just after 7am or about 9pm.
Message posted on 13 Aug 2023 10:50 AM
@Mo Unless I'm misunderstanding, you currently have a Sky+HD box but only use it for Freesat (ie without a Sky subscription) and want the same in another room?
If that's correct, you could source a used Sky+HD box from eBay and pay a local satellite company to install it for you.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Message posted on 13 Aug 2023 11:58 AM
Thank you @oj01
Does that mean I also have to have a second satellite dish installed? I'd rather not.
Message posted on 13 Aug 2023 01:47 PM
No, but you'll need an additional cable installed from the dish to wherever you want to put the second Sky box.
