7
This discussion topic has been answered Discussion topic: Activate my sky card when away from home on the sky app? Sky plus
This message was authored by: shazzar33
When I go and stay in my caravan I take my sky card with me and activate it to a sky plus box, usually go onto the sky app and can activate my card and just type in the version number etc.
went onto the sky app and it's all changed and says go to manage my account then TV then activate my card. But I can't find any of those on the sky app , where has it moved to???
Re: Activate my sky card when away from home on the sky app? Sky plus
@shazzar33
Your viewing card is only supposed to be used at it's registered address as this is covered somewhere in the terms and conditions.
The option to do this via the app doesn't appear to be present anymore but looks like it can be done here:
https://www.sky.com/myaccount/tv/card-pairing
@shazzar33
Avatar for shazzar33
Level 2 icon
@caesarome
Thank you , where did you find the link? I couldn't find it anywhere
It can be found via your account settings here:
Level 2 icon
Thank you it worked on the first link you sent but the second link is the same one that I can get to from signing in but can't activate my box from it
thanks for your help 👍👍
The first link may disappear with time as Sky complete the task of ending Sky+ support🤔
Level 2 icon
@Exiled-in-HH
I have now saved to my desktop and hope the link will still be available when I need it next weekend 😱 as for them stopping sky plus I did check our amstrad series number and it's not in the first lot that they are turning off so hopefully keep for a bit longer
@shazzar33 wrote:
@Exiled-in-HH
The second link that's you said was on their website has gone ... the first link that you couldn't find may well follow and disappear ... as Sky complete their task to end Sky+ support😉
