Sky TV Remote Control Codes
You get a Sky Remote manual when you get your Sky box. This includes a list of TV manufacturers’ names at the back and a code list. The steps below will help you understand how to program/fix Sky Remotes with 3 digit remote codes input.
Note: There are multiple versions of Sky Remote Controls available to purchase online or in retail; if you get a new remote, make sure it's the most recent version. Refer to the Code according to the brand of your TV.
  • First, turn on your Sky Box and TV.
  • On your Sky Remote, press the TV button.
  • Press the Select and Red buttons simultaneously until the red LED on your remote blinks twice.
  • Enter the 3 digit Remote Codes for Sky TV in the box. The light should flash twice on the remote.
  • If it just blinks once, repeat steps in the following number.
  • Press the Standby button on your remote.
  • If your television turns off, press the Select button to save the setting.
  • Turn on the TV and press TV Guide; if the TV Guide list displays on the screen, the programming was successful.
If you can't manage or operate your Remote using a 3-digit remote code, a 4-digit code can be used. Follow these steps if that applies to you:
  • Turn on the Sky Box and TV.
  • On your Sky remote, press the TV button.
  • Hold down the Select and Red buttons at the same time until the red LED on your remote blinks twice.
  • On your Remote, press the TV button and enter the 4 digit Sky remote codes for the brand of your TV.
  • On the Remote, the light should flash twice.
  • If your TV turns off, press Select to save your settings.
  • If the TV does not turn off, hit TV and then Standby repeating the process until the TV turns off, then click Select to save.
  • Turn on the TV and press the TV Guide button; if the TV Guide list displays on the screen, the programming was successful.
