- Mark as Read
- Report comment
Sam-R
This guide shows how to program the Sky remote to control audio-visual equipment, such as home cinema surround sound systems, using remote codes.
For home cinema surround systems
Step 1: locate your code from the table at the bottom of the page. Manufacturers are in alphabetical order. You can use the Ctrl-F search function on your browser to find your code quicker.
Step 2: Hold down select and 0 on your remote until the LED flashes twice.
Step 3: Enter your four digit code. The LED should then flash twice.
Step 4: Press the left arrow button. If you device goes into standby then the correct code has been selected.
*Please note, Sky does not currently support sound bars but the manufacturer codes below may work.
It's super easy to programme your remote on our next generation box. Check out the latest offers.
When listening to sound through an amplifier and not the TV
Step 1: locate your code from the table at the bottom of this page. Manufacturers are in alphabetical order. You can use the Ctrl-F search function on your browser to find your code quicker.
Step 2: Press TV then hold down select and 1 together until the LED flashes.
Step 3: If the LED flashes twice, it will control the sound of your amplifier when volume up, down or mute are pressed and your TV sound if arrow up, down or right are pressed.
Step 4: If the LED only flashes once, or remains on steady, retry the procedure. If your remote still does not flash twice the remote does not support this feature.
To reverse any of these settings
Press the TV button then hold down select and 2 together until the LED flashes twice.
For further help with anything in this guide, you can head over to our dedicated Sky+ discussion area.
| Acoustic Solutions | 1496 1498 1529 1474 |
| AEG | 1418 1417 |
| AFK | 1417 |
| Aim | 1418 |
| Aiwa | 0149 0187 1433 1086 1186 1286 1650 1850 1750 |
| Akai | 0374 0143 0468 0637 1248 1418 1206 |
| All-Tel | 1418 |
| Amstrad | 0772 1418 |
| Anam | 637 |
| Apple | 1143 |
| Arcam | 0669 1117 1217 1240 1297 1317 |
| ASCOMTEC | 1417 |
| Audiolab | 1117 1217 1297 1317 |
| Audiosonic | 1417 |
| Audiovox | 1436 |
| Audioworld | 1418 |
| Balanced Audio Technology | 1117 1217 strong>1297 1317 |
| Bang & Olufsen | 827 |
| Basic Line | 1409 1582 |
| Belson | 1409 1417 |
| Binaura | 1723 |
| Blue Sky | 1418 |
| Bonnec | 1217 |
| Bose | 1257 1281 1657 1383 1385 1961 |
| BSkyB | 1525 |
| Bush | 0449 0875 1117 1217 0825 1297 1317 |
| Cambridge Audio | 1675 1217 1758 1483 2010 |
| Cambridge Soundworks | 1499 |
| Carver | 388 |
| CCE | 1380 |
| Centrex | 1285 |
| Centrum | 1582 1248 1417 |
| Classic | 1380 |
| Clatronic | 1248 0772 0825 |
| Copland | 1117 1217 1297 1317 |
| Cosmotron | 825 |
| Creative | 1499 |
| Curtis Mathes | 328 |
| Daewoo | 1206 1278 |
| Denon | 1388 1132 0300 2885 0032 1462 |
| Denver | 1417 |
| DeToma | 1123 |
| Diamond | 1418 |
| Digitrex | 1285 |
| DiK | 825 |
| DK digital | 1448 |
| DMTECH | 1418 |
| Dual | 1248 1418 1448 0032 |
| Durabrand | 1596 |
| eBench | 0772 0825 |
| Electrocompaniet | 1217 |
| Elta | 0772 0825 1418 |
| Enzer | 1409 |
| Eroica | 468 |
| Fisher | 388 |
| Garrard | 0468 0772 |
| Genexxa | 0214 0468 |
| Goldmund | 1117 1217 1297 1317 |
| Goodmans | 0637 0772 0468 0825 0374 1206 1227 1448 1417 1525 1618 0449 0875 |
| Grundig | 0875 1496 1117 1217 0772 1372 0825 1297 1317 |
| Grunkel | 772 |
| Hanseatic | 1418 |
| Harman/Kardon | 1332 1338 1117 1217 0138 1334 1297 1317 |
| Harwood | 772 |
| HCM | 1418 |
| HE | 1417 |
| Hitachi | 1372 1248 1582 1809 1811 1227 |
| Hiteker | 1417 |
| Höher | 1285 |
| Home Tech Industries | 1417 |
| Inkel | 0519 0530 |
| Integra | 1833 |
| Intersound | 772 |
| Jamo | 1592 |
| JBL | 0138 1334 1205 0696 |
| JVC | 0102 0492 1523 1402 1704 |
| Kenwood | 1341 1055 1597 0214 0290 1321 |
| Kinyo | 1123 |
| Kiss | 1592 |
| Kompernaß | 825 |
| Koss | 772 |
| KXD | 1417 |
| Lenoxx | 1417 |
| LG | 1321 1552 2225 2417 |
| Lifetec | 825 |
| Linn | 1117 1217 1297 1317 |
| Loewe | 1117 1217 1297 1317 |
| Logitech | 1436 |
| LXI | 772 |
| Magnat | 1205 |
| Magnum | 1629 |
| Marantz | 0349 0669 1117 1217 1297 1317 2142 |
| Mark | 1117 1217 1297 1317 |
| Matsui | 0825 0772 |
| MBO | 1380 |
| MCS | 374 |
| Medion | 0825 1448 2225 |
| MEI | 1418 |
| Melectronic | 637 |
| Meridian | 1117 1217 1297 1317 |
| Metz | 1582 |
| Micromaxx | 1448 |
| Micromega | 1117 1217 1297 1317 |
| Microstar | 825 |
| Midiland | 1123 |
| Minton | 1123 |
| Mitsubishi | 468 |
| Musical Fidelity | 1747 |
| Mustek | 1380 1618 |
| Mx Onda | 0772 1525 0825 |
| Myryad | 1217 1117 1297 1317 |
| NAD | 0348 0637 1771 2017 |
| Naim | 1117 1217 1297 1317 |
| NEC | 1278 |
| Nexius | 1418 |
| Nikkai | 1417 |
| Nikkei | 772 |
| Okano | 0468 0637 |
| Onkyo | 1348 0163 1833 |
| Optimus | 214 |
| Orava | 1417 |
| Orient Power | 772 |
| Oritron | 1525 |
| Palladium | 0825 1248 1552 |
| Panasonic | 1807 1546 1791 1793 1337 1336 1344 |
| Paramount Pictures | 1248 |
| Philips | 0669 1646 1217 1117 0374 1701 1297 1317 1294 1682 1859 2339 |
| Phonotrend | 530 |
| Pioneer | 0328 1051 0317 0214 1151 1212 1117 1217 1312 1487 0851 1297 1317 1651 2132 1963 1851 |
| Prima Electronic | 825 |
| Proline | 0825 1418 1285 |
| Proson | 637 |
| Provision | 1417 |
| QONIX | 1448 |
| Quad | 1117 1217 1297 1317 |
| Quelle | 1206 |
| Radiola | 1117 1217 1297 1317 |
| Radionette | 1321 1662 |
| RadioShack | 772 |
| RCA | 374 |
| Red Star | 1409 1417 |
| Reoc | 1409 |
| Revox | 1117 1217 0214 1297 1317 |
| Revoy | 1117 1217 1297 1317 |
| Roadstar | 0374 0825 0875 |
| Rotel | 0821 2031 |
| Saba | 1182 |
| Saisho | 374 |
| Samsung | 1227 1452 1323 1609 1896 2165 |
| Sansui | 0349 0637 0374 1117 |
| Sanyo | 0388 1829 0772 |
| Schneider | 0772 1418 1206 1227 1248 0138 |
| SEG | 1278 1582 |
| Sharp | 0214 0290 1642 1662 |
| Sherwood | 0681 0530 0519 |
| Siemens | 637 |
| Silva Schneider | 1552 1321 0825 |
| Sky | 1525 |
| Sony | 0187 0717 1186 1886 1786 1086 1686 1286 1650 1850 1786 1482 1586 1469 1750 1140 1850 2200 |
| Soundwave | 637 |
| Sunstech | 1448 |
| Sven | 1596 |
| Synn | 1409 |
| T+A | 1714 |
| TaeKwang | 468 |
| Tag McLaren | 1217 |
| Targa | 1321 |
| TCM | 825 |
| Teac | 0449 1227 0825 0637 0772 1418 1206 0138 1637 |
| Technics | 1791 1546 1807 1337 1336 1793 1344 |
| Techwood | 1582 |
| Telefunken | 0875 1418 1417 |
| Tevion | 1629 |
| Thomson | 1382 1525 1182 |
| Thorens | 1217 1117 1297 1317 |
| Thorn | 772 |
| Toshiba | 1600 |
| Trice | 1596 |
| Uher | 374 |
| United | 1418 |
| Universum | 1206 1248 0825 0637 1418 0772 0468 1117 1217 1637 1297 1317 |
| upXus | 1474 |
| Venturer | 1418 |
| Victor | 102 |
| Videologic | 1123 |
| Vieta | 1205 |
| Voxson | 1448 |
| Waitec | 1380 |
| Watson | 825 |
| Wellfund | 772 |
| Welltech | 825 |
| Wharfedale | 0468 0637 1418 |
| Xenon | 1417 |
| Xitel | 1143 |
| X-Tensions | 1123 |
| Yamaha | 0171 0876 0382 0204 1304 0740 1359 0214 1843 2049 2089 2144 2370 2365 |
| Yukai | 1380 |
| Zenith | 772 |
Leave a comment
Comments have been disabled
Comments (0)
