Discussion topic: sky stream playlist is showing F1 episode Part Recorded
This message was authored by Robbinz This message was authored by: Robbinz
Hi all,
Firstly I really hate sky stream.
So the F1 episode I was trying to watch  Is showing as part recorded, but im confused as I thought these were all streamed off the cloud? So how van it be part recorded? It can see that it is halfway through the show on the episode thumb, but it gets to 1hr 1 min and then stops. Anyone else having this issue?
This message was authored by best+of+the+best This message was authored by: best+of+the+best
Re: sky stream playlist is showing F1 episode Part Recorded
  • @Robbinz wrote:
    Hi all,
Fair comment @Robbinz only thing I can think of is that F1 is available on two channels for the HD versions
The dedicated channel Sky Sports F1 HD Channel 406 and the bonus Channel 401 Sky Sports Main Event HD
Only way I can think of why it's been part recorded is it possible SS Main Event HD channel 401 was selected
instead of SS F1 HD channel 406
If it was selected from Main Event probably something else other then F1 was scheduled to be shown also
The way for you to check this is by going to other showings for the next session which is what I call the pre-GP session the build up to the actual race which starts 12:30pm this session is not on SS MEvent HD channel 401 as they are showing Live S/Lge Magic Weekend
Now if you select the Live Spanish GP which starts at 2:00pm today then select other showings you should see
Sky Sports Main Event HD 2:00pm
Sky Sports F1 HD                     1:55pm
Apologies if you had selected the correct channel maybe a  one off
Robbinz
Hi best+of+the+best,
So I fully understand where you are coming from. Though the image shows that the playlist is taking it from SkySportsF1 and not main event.
I tried rebooting and going back into F1Live and F1 playlists to watch it, but it was still timing out jusy after an hour.
Disappointing, but i guess its just a (another) glich in the system.
Thanks for taking the time to respond though.
Best Regards,
Steve
