Discussion topic: sky puck. wifi or wired in?
Message posted on 14 Jan 2025 01:32 PM
Having just got a sky puck.. Brilliant little device, that works on wifi. Using it for the first time (as I type) i have had a streaming issue, and as i have my broadband router in the same room, would it be better if i wired it straight into the routher instead if the wifi signal? its literlly 10 yards away from it?
Message posted on 14 Jan 2025 01:49 PM
Re: sky puck. wifi or wired in?
That's often preferable, yes, with the WiFi on the puck switched off.
Message posted on 27 Mar 2026 12:02 AM
Ive discovered in Netflix using the built in speed check that my wireless speed connection is quicker than the wired. May be worth checking for your connection. In Netflix click Get Help then Check Your Network.
Message posted on 27 Mar 2026 08:00 AM - last edited: 27 Mar 2026 08:03 AM
That's quite likely to be the case, because a puck is WiFi 6 but only has a 100Mbs ethernet chipset. However Netflix only needs around 25Mbs at most and the reliability of data over a cable is preferable to any fast but potentially fluctuating wireless connection.
