Discussion topic: sky atlantic pin number required
Message posted on 03 Mar 2024 05:03 PM
I understand I need a pin number to access sky atlantic I am on sky stream
Message posted on 03 Mar 2024 05:06 PM
Re: sky atlantic pin number required
@bridgebum The PIN number should be the last four digits of the mobile number registered on your sky account
Message posted on 03 Mar 2024 05:22 PM
@bridgebum you don't need a PIN specifically for Atlantic. It is required for any post watershed programming that is being shown pre-watershed. Atlantic does this quite a lot.
The PIN it is looking for is your standard Sky PIN but if you have not set one up then it will be the last 4 number of your phone number registered with Sky.
