Discussion topic: since upgrade from skyQ to steam paramount+ will not activate
This message was authored by edgeedge This message was authored by: edgeedge
i keep getting the following message evry time i try to active,
"It looks like you might have tried to access this page too quickly"
everyday i try again but nothing.... vitual assistant needs deleating what a waste of code.
This message was authored by Fothergill1 This message was authored by: Fothergill1
Re: since upgrade from skyQ to steam paramount+ will not activate
@edgeedge Have you looked at the Using Paramount + with Sky link.  There may be something there that might help you.  If after following the various steps you are still having trouble there is a link at the bottom of the page "No, I still need help" if you follow that link through to the end it will give you a phone number to use to phone SKy for further help.
Also, if you type Paramount into the search bar at the top of this page it will show you other threads relating to P+ where you might find some useful information.
If my post has solved your issue please mark as an "Answer"
