Discussion topic: no tv programmes due to technical error
This message was authored by: Molly65
When I click a programme on live TV or playlist nothing happens.  A message says there's a technical error and to try again later. My broadband connection is fine.
This message was authored by: Steve93
Re: no tv programmes due to technical error
Try resetting the puck, press the microphone on the remote & say settings, then go to system management, resets & updates, then restart device, see if that sorts the problem out.
