Discussion topic: discovry plus keeps saying i need to upgrade
This message was authored by: MK3CORTINA
i have  discovery plus on the app but when i try to watch anything it keeps saying i need to upgrade
Re: discovry plus keeps saying i need to upgrade
Are you sure you successfully completed the Discovery+ registration procedure on the Puck?
Avatar for MK3CORTINA
Yes. Both logged in using same account. My sky says i am conected but when i clickbon something to watch ut asks for me to upgrade
Hi @MK3CORTINA Have you actually registered for Discovery +?  If not you should be able to register as follows:
Go to the bottom of the home page and select the following in this order: MySky / your products / (enter your PIN) / App Subscriptions
Select App subscriptions / Current / and then Discovery + Monthly.  Hopefully it will say £0 per month whilst you have a Sky TV Subscription. If so select Activate subscription.
Also, see the following link:
https://www.sky.com/help/articles/sky-marketplace-subscribe-to-discovery-plus
Good luck 🤞
Do not have discovery plus on the list. And not in shop either
@MK3CORTINA  would you like me to escalate your post for an online chat with the Community Messaging Team?
Already esculated thanks
Was it there when you followed the procedure to register Discovery+ on your Puck?
It used to work then its stopped new box
Was the old box a Puck?
