Discussion topic: Wont work in two rooms at same time
This message was authored by: Eileen14
When i try to turn on sky stream box's in 2 seperate rooms at same time only one will work, the other one keeps freezing and is very slow loading
This message was authored by: Nigelb1972
Re: Wont work in two rooms at same time
What speed broadband do you have? As that sounds like your maxing out your bandwidth
@Eileen14  I would agree with @Nigelb1972  regarding speed issues.
For each puck you need a minimum of 25mbps for HD & 35mbps for HD
If you line speed is only around 20 to 30mbps then running 2 pucks at the same time will be an issue.
