Discussion topic: Why does my sound not sink when l turn on the tv it take about 30 seconds. Then sometimes sound go?
This message was authored by: Terry421565
Message posted on 21 Mar 2024 11:03 AM
Why does my sounds take time to come on after the picture. Probably 30-40 seconds. Then goes sometimes within a program
Find out more
Message posted on 21 Mar 2024 02:19 PM
Re: Why does my sound not sink when l turn on the tv it take about 30 seconds. Then sometimes sound
@Terry421565 it could be because it is taking time for the TV to identify the audio codec and lock onto the signal. You could try changing the audio output type in the settings from the default auto to pas through see if that helps. If you are using your TV's speakers for the sound then it is possible PCM Stereo would becthe best choice as the simplest type of audio.
