Discussion topic: Why does my sky stream keep freezing saying programme loading
This message was authored by: EllaJale123
My sky stream is constantly freezing saying "technical fault" or "programme loading" it also keeps saying there is bad Internet connection when my Internet is working just fine. Why is this happening please help?
Re: Why does my sky stream keep freezing saying programme loading
@EllaJale123  How is your puck connected to the hub?  Are you connecting over wifi?   Have you tried ethernet?
This message was authored by: Deedee36
@EllaJale123  How are you connected to the internet is it wifi or Ethernet?Also powering off your device and removing the plug from the wall for a few minutes,can sometimes help fix some issues.if this doesn't work launch the Netflix app scroll down to get help and run a network connection test this will give you the speed your device is recieving
“Trying to help improve sky glass”
