Discussion topic: Whole home required
Message posted on 30 Oct 2025 05:08 PM
Whole home required
My sky puck is stuck on the whole home required page and won't go to tv list or any apps !?
Message posted on 30 Oct 2025 05:17 PM
Re: Whole home required
Switch off your Sky Stream puck at the mains and then switch it back on again. There’s no need to unplug it
Message posted on 30 Oct 2025 05:19 PM
Thank you but tried that and still won't!
Message posted on 30 Oct 2025 05:24 PM - last edited: 30 Oct 2025 05:24 PM
Ok thanks.
Have a read of this Sky help article, namely doing the recovery procedure on step 4.
Message posted on 30 Oct 2025 05:31 PM
No doesn't work , nothing wrong with power source or remote just stuck on the whole home required screen , I can open up settings
Message posted on 30 Oct 2025 07:43 PM
Hi @Aj112
Do you have more than one puck? Do you have whole home?
Is the puck showing as the primary device on your account?
See: https://www.sky.com/help/articles/your-devices-sky-glass
MikeAlanR
Message posted on 31 Oct 2025 04:56 AM
Did you complete the recovery procedure?
That should refresh a stuck issue like this.
If, you did complete the recovery procedure and your Puck is still getting stuck on Home Screen, best to give Sky a call for further diagnosis.
