7
Discussion topic: Where to put activation code for sky stream
This message was authored by DaniMac This message was authored by: DaniMac
Where do I put in the activation code? I can't find it when I follow the link.
This message was authored by Tim+Adams This message was authored by: Tim+Adams Answer
Re: Where to put activation code for sky stream
@ThunderCatsHo1970 wrote:
How do I link my account
Hi @ThunderCatsHo1970
Try logging into www.sky.com first then press the link below,
https://www.sky.com/productsettings/streaming-tv/activate
Thanks,
Tim
Sky Glass with Sky Live, Sky Stream & Sky Protect - FTTP 2Gbps
This message was authored by mikealanr This message was authored by: mikealanr
Hi @DaniMac
It's www.sky.com/activate - you need to log on with the account / email you purchased Stream / Glass with.
MikeAlanR
65” Sky Glass ocean blue, Sky Live, 4 streaming pucks and EE FTTP Busiest Home (circa 1.6 Gbps download). Former Sky Q, Sky+ HD and Sky+ customer.
This message was authored by ThunderCatsHo1970 This message was authored by: ThunderCatsHo1970
Thanks,
Tim
This message was authored by Zak08 This message was authored by: Zak08
Where do I put the activation code
@Zak08  Please see the reply immediately above your post.
This message was authored by Bernardett This message was authored by: Bernardett
I need to put my code in to get sky glass on
This message was authored by AnnaLH This message was authored by: AnnaLH
I seem to be having the same issue as many others. Asked to enter an activation code, follow the link, get an 'Oops there's a problem' message. I called Sky and they advised accounts should be activated automatically without having to enter in an activation code and that this is a 'known problem'. A support ticket was raised and I was meant to be hearing back from Sky within 72 hours (which is today). Fingers crossed the problem gets rectified.
