Discussion topic: Where can I get a replacement remote for sky stream?
This message was authored by: Amn3
Message posted on 19 Dec 2025 08:57 AM
Does anyone know where I can get a replacement remote for sky stream in Ireland?
Find out more
Message posted on 19 Dec 2025 09:09 AM
Re: Where can I get a replacement remote for sky stream?
@Amn3 Have you tried online? https://www.sky.com/shop/accessories
Find out more
Message posted on 22 Dec 2025 11:29 PM
Hi @Amn3 and welcome to the forum. You can also get them from Amazon at this LINK.. They are dispatched from Amazon but are supplied by Concino Limited who are an official Sky partner so the remotes are genuine and not cheap copies. They cost £29.99.
