Discussion topic: What to expect via post when purchasing Sky Stream
This message was authored by: CHM12
What do I receive via post when purchasing Sky Stream (TV and Broadband)? I've received the Sky Stream 'Box'.  I've missed a British Mail delivery twice (a different problem that). But what is it that must still be delivered aafter the 'box'?
This message was authored by: Jporch316
Re: What to expect via post when purchasing Sky Stream
I'm all probability a sky router if you are a new customer to sky internet
43inch Gen 1 and 55 inch Gen 2 Sky Glass & sky live camera 3 Pucks. Virgin media M350 hub 5x. Four sky mobile sims.
The Sky stream puck can be installed straight away, you don't need to wait for your Sky broadband to be installed.
I suspect the other package you're expecting is the Sky router.
@CHM12
You can setup the sky stream tv box with any internet connection.... you don't need to wait for you sky internet to go live
your billing cycle will commence once the stream tv is activated or 30 days after receipt
Avatar for CHM12
Level 0 icon
Thanks Josh. I've just connected via a different internet provider and it is up and running. The deduction is then what you've just explained, thanks. It is just that an Openreach technician is arriving tomorrow at 7.30 am (!) and I thought the package might've been needed by him. Thanks again!
Enjoy !
@CHM12 I imagine that the open reach engineer won't require the package but once they've done their bit it might be that you lose internet access until your router arrives and you can connect it.
