Discussion topic: Volume very quiet sky stream puck
This message was authored by mcnillis This message was authored by: mcnillis
Hi,
I received a sky Puck today and is all set up. However I have to turn the volume up extremely high just to get to normal sound levels. If I then switch back to the firestick, it is way too loud.
Do sky compress their sound a lot?
Many thanks
This message was authored by Jonjoe This message was authored by: Jonjoe
Re: Volume very quiet sky stream puck
Same here.
Switch source and the volume blows your head off!
Very annoying..
This message was authored by Anonymous This message was authored by: Anonymous
This is one problem I've never experienced the volume is stable across all connected devices including Stream.
mcnillis
I'm using a Sonis arc sound bar, not sure if it doesn't pass the sound through very well?
I'm using Optical / HDMI ARC out from an LG TV to a Samsung sound bar..
I have similar set up via Sonos.
mcnillis
Are there any specific audio settings you use withing the puck?
