Discussion topic: Voices in Sky puck sound like a dalek.
Message posted on 07 Apr 2024 04:38 PM
Voices on TV programs on the sky puck sound like a dalek on all channels. I've turned it on and off and no joy. The main sky glass TV is fine. I followed the instructions on self help to check digital sound output settings they were on auto as they were supposed to be - I've changed them to Dolby dogital plus and it works fine, not sure why it's suddenly gone weird?
Message posted on 07 Apr 2024 05:00 PM
Re: Voices in Sky puck sound like a dalek.
@Yipfandango Have you tried unplugging the puck for a couple of minutes?
Message posted on 07 Apr 2024 05:01 PM
Hey, yep have done that - unplugged left for 5 mins as per instructions no luck. Reset WiFi connection, have done everything I can think of.
Message posted on 07 Apr 2024 05:08 PM
@Yipfandango Did you set the soun opti ns back to where they were? Have you tired adjusting the sound settings on your TV also as the TV may not like the current sound settings from the stream puck.
Message posted on 07 Apr 2024 05:43 PM
Hi, yep. If I set it back to auto as it was (and as the help screen says) I get the weird voice, but if I set to Dolby it's fine. Nothing has changed - it's just started doing it. TV settings are ok.
Message posted on 07 Apr 2024 05:44 PM
@Yipfandango If it's findeon dolby I would leave it on that setting.
Message posted on 07 Apr 2024 11:01 PM
Mine has done this exact same thing today (7th April) - I've set my sound from auto to Dolby and it works fine again.
if I set it back to Dolby plus or auto I get the distorted sound once more.
mist be an update issue maybe? Only happened from this morning when I turned the tv on.
Message posted on 08 Apr 2024 08:22 AM
That's exactly the same for me. Weird. Will leave it on Dolby until sorted. The main sky glass TV is fine.
Message posted on 08 Apr 2024 08:56 AM
@L22MRG wrote:Mine has done this exact same thing today (7th April) - I've set my sound from auto to Dolby and it works fine again.
Sky are investigating some sound issues at the moment, mainly around lip sync that seems to have been caused by the recent puck firmware upfate.
Some TVs and soundbar combinations often do get in a muddle when devices switch sound settings.
When doing a switch, it is best to put your TV and puck into standby and then remove the power plug or turn off socket for a few minutes on both.
It is often also a cure, when a certain sound setting goes array.
Put the puck into auto and do the powere remove on the TV and puck. The auto setting on the puck is a kind of reset flag for the audio.
