Discussion topic: Voice control on the remote
Message posted on 29 Jun 2025 02:56 PM
Message posted on 29 Jun 2025 03:11 PM - last edited: 29 Jun 2025 03:12 PM
Re: Voice control on the remote
@Unhappy67 Not me - but I don't use voice control. I always find it very frustrating. I think the feature doesn't cope well with a Yorkshire accent!
Message posted on 29 Jun 2025 03:37 PM
@Unhappy67 wrote:
Been with sky about 6 weeks and gone through 4 remotes. Anyone else having issues with voice control working, then not. It's frustrating and unacceptable. Sky customer service are useless when asked.
Never had any issues with voice control on my remotes (3 pucks and 2 glass) that wasn't fixed by a restart or plug pull
what kind of problems are you encountering with the voice control ?
Message posted on 29 Jun 2025 03:45 PM
There was a small blip last month or so, I recall, fixed promptly.
I use voice a lot every day, searching, channel swapping, app launching, calling menu options like Settings.
Apart from that blip, above, been working fine of late with no issues.
As above, do a settings restart of your puck;
Go to Settings>Systems Management>Resets & Updates
Select Restart device
Your Sky Stream puck will perform a reboot. It will take a few minutes to complete
Message posted on 29 Jun 2025 03:47 PM
It either does the "say it again" or highlights at the top with nothing at all. I'm sick of plug pulls and restart/pairing. I shouldn't be doing it 2 or 3 times a day.
It's as bad, if not worse than virgin was
Message posted on 29 Jun 2025 03:49 PM
I'm doing it 2 or 3 times a day. It's getting silly now.
Message posted on 29 Jun 2025 04:08 PM
@Unhappy67 wrote:I'm doing it 2 or 3 times a day. It's getting silly now.
And this is sky stream ? Or glass ?
Message posted on 29 Jun 2025 04:40 PM
Stream and puck
