Discussion topic: Voice activation on remote does not work
This message was authored by: NG8
When i press the microphone button on my remote it pairs with the box/tv and the coloured bar is visible on the tv, but there is no respose to my command. It eventually goes red and comes up with a message telling me to leave my finger on the button longer.
I have restated both the puck box and the remote, replaced the batteries in the remote and i still have the problem. Please help !
Re: Voice activation on remote does not work
Try rebooting your broadband router also, that often helps with this issue.
This message was authored by: HavencroftKev
When you say restarted your remote, what do you mean?
Try holding buttons 7 & 9 together for 3 seconds.
Then holding buttons 1 & 3 together for 3 seconds.
Failing that if the issue is still there you might need a new remote.
I'd always recommend replacing the batteries in your remotes with rechargable batteries, not using the ones that come with the remote.
I had these ones with the remote leak and damage the remote (duracel too), I've also read of numerous other similar cases.
wonder if Sky just bought up a load of old soon to be trashed batteries from Duracel on the cheap?
Avatar for NG8
Thanks for the replies.
I dont think it has anything to do with the wi-fi as we get the coloured bar appear on the tv when we press the mic button.
I re-installed the remote again, and it has started working. I think youre right re the batteries, and am going to replace now its working, and set a 6 month reminder i think ! 🙂
Thank you again for taking time to reply. !
