Discussion topic: Voice Guidance not Working on Sky Stream
This message was authored by: Gm1992
Hello,
I am trying to enable Voice guidance on the Sky stream. When I turn this on and press the home button, the sound of the tv programme is silenced. However, there is no speech. Has anyone else had this issue?  If so, is there a fix?
Many thanks for any help.
George
Re: Voice Guidance not Working on Sky Stream
@Gm1992 not all programming comes with Audio Description as explained here https://www.sky.com/help/articles/finding-audio-description
Avatar for Gm1992
Thanks for replying. To clarify, I am referring to the speech developed by Sky which reads out the menus and tv guide etc. I understand this should be available with the Stream.
I've tried voice guidance on Sky Stream and it works well. Just as it did with Sky Q.
Its nice that you can turn it on/off with voice 'turn on voice guidance' 'turn off voice guidance'
Just put it on and all working fine.
One thing to check, is that you are not using the audio setting 'pass through' as it does not work correctly when that is enabled.
Setting to PCM or either of the Dolby options works fine though.
If above still does not help, try restarting your puck, by putting into standby and removing the power plug or switching off your power socket for about a minute and then repower up again.
This message was authored by: Padam_Padam
Instructions for voice guidance on Sky Stream are here:
https://www.sky.com/help/articles/voice-guidance
Avatar for Gm1992
Thank you very much for the advice. Unfortunately, I have tried all of the suggestions without success.
This message was authored by: Chloe-W22
Posted by a Sky employee
Hi @Gm1992,
Have you tried resetting both the BB router and also your Sky Stream?
Chloe-W22
Sky Community Manager
Have a story you want to share with us? Send your Thanks to Sky here
