Discussion topic: VESA Mount for Sky Stream
This message was authored by tweetSP0RT This message was authored by: tweetSP0RT
This is a bit of niche use case but I want to mount some pucks behind spare monitors to act as a additional screens particularly for using Sky Race Control during F1.  I've got a couple of those USB-A to 3.5mm barrel plugs for power delivery so they can be just pluged into a sufficiently powerful USB charger..
So ideally I'd like a VESA mount solution but I can't seem to find any I can find a couple of wall mounts for the pucks I wonder if anyone has one/perhaps jerryrigged a solution (3D printed perhaps?).  VHB tape would work but probably not ideal for either the monitor or the puck (I'd have to make sure I use the pucks I own rather than those I 'rent' thanks to Sky changing their T&Cs😠")
I can obviously just put them on the table top etc. but would be neater if it could be permanently mounted then they can be easily picked up and put away when not in use.
