3
This discussion topic has been answered Discussion topic: Update remote control and reset to default
This message was authored by: Marco5
Remote control will not update and reset to default
This message was authored by: Jporch316 Answer
Re: Update remote control and reset to default
@Marco5
The remote can be reset and paired again following these steps;
  1.   Press and hold 7 and 9 together on your Sky remote for three seconds.
  2.   Press and hold 4 and 6 together for three seconds.
  3.   Press and hold 1 and 3 together for three seconds and follow the on-screen instructions.
@Marco5
This message was authored by: Cottager
I tried all the advice but remote not switching sky tv on
@Cottager
You can use the sky remote app on android or apple phones to control your tv
would suspect you have a faulty remote (assuming you ve changed the batteries)
there's troubleshooting guide on the sky website for remotes which if found faulty will give you a link for warranty replacement
