Discussion topic: There is a technical fault
This message was authored by: Gustavo123
Message posted on 22 Oct 2025 09:43 PM
I've never been able to watch The Celebrity Traitors from the start when it is on. I do not get the "watch from the start" button when I go to the channel and if I slect the programme from the playlist -> Select "watch from start" from there, I get the error: "There is a technical fault with this programme. Please try again".
Find out more
Message posted on 23 Oct 2025 06:02 AM
Re: There is a technical fault
You've posted on the Sky Q board but you've mentioned'playlist' which is a term used with Glass/Stream so to get the best advice can you confirm which platform you subscribe to?
Message posted on 23 Oct 2025 06:11 AM
Hi Daniel,
I have a Sky Stream puck.
Find out more
Message posted on 23 Oct 2025 06:13 AM
I'll move your thread to the correct board. Your duplicate thread on here has also been removed to prevent duplication of replies.
