Discussion topic: There is a technical fault with this programme. Please try again later.
Message posted on 22 Jun 2024 12:25 PM
Re: There is a technical fault with this programme. Please try again later.
@Robert0072 wrote:I made a mistake. It must have been the Poland Austria game. Either way, can we keep this thread on topic?
Either way if there's an issue with a channel on the tv guide you could have watched via one of the corresponding apps on the puck
who is your internet with ? I know some providers sometimes use non uk ip addresses occasionally .... turning off your router at the main for a few minutes can get your router to pick up a different IP address
Message posted on 22 Jun 2024 12:25 PM - last edited: 22 Jun 2024 12:32 PM
@Robert0072 wrote:Connection speed is 89.83Mbps
Was that via the Puck Netflix test on ethernet?
Does your ethernet go direct from puck to router or via a switch?
Sometimes, ethernet switches have been known to be a tad temperamental, was a known cause case for Sky Q, so perhaps could be causing a glitch somewhere on Sky Stream.
If on ethernet, try the following; in this order, even if you have tried something similar before.
Make sure in the puck Settings>Start up and standby that Network standby mode is set to ON and overnight power saving is set to OFF.
Make sure in the puck Settings>Network>Advanced settings that WiFi is set to OFF (if you are using an ethernet connection).
Press the Standby button on your Sky remote or on the bottom of your Sky Stream puck.
Switch off your Sky Stream puck at the mains or remove the plug from the socket.
Switch your broadband router off at the mains or reboot it.
Wait for about 30 seconds then switch the broadband router back on at the mains or just let it reboot itself if you used the reboot method.
Wait for all the lights to come back on on your router and check that your other devices are connecting to the internet.
Switch your Sky Stream puck back on at the mains or put the plug back in the socket.
Message posted on 22 Jun 2024 01:16 PM
Router to puck. I've done those steps. The settings were already as described.
Message posted on 22 Jun 2024 01:45 PM
Which internet provider are you using? There can be occasional issues with some ISP s especially mobile phone isp s like 3
Message posted on 22 Jun 2024 06:37 PM
There are issues with hyperoptic internet - there's a thread from a couple of days ago where users were unable to pick up an internet connection on hyperoptic
You need to raise the issue with hyper optic and I will escalate in the superuser forum
Message posted on 22 Jun 2024 06:53 PM
If the ISP is Hyperoptic there is a ongoing issue as reported in this thread https://helpforum.sky.com/t5/Sky-Stream/Sky-Stream-Hyperoptic-Broadband-issues/td-p/4674074
Message posted on 23 Jun 2024 08:58 AM
No one has determined if the issue is associated with Hyperoptic or SKY. You could argue that only HO customers are having an issue. But then you could argue the only device they are having an issue with is SKY.
Message posted on 23 Jun 2024 09:21 AM
@Robert0072 I'm not having these issues on Virgin Media ,from the posts in this forum there is an issue with HyperOptic customers and not purely a Sky issue.
The posts speak for themselves.
Message posted on 23 Jun 2024 04:40 PM
I agree that the only people affected seems to be HO customers. But as an engineer, i would be wary of simply saying "its a fault with HO". I may well be. But unless some kind of analysis is done, no one will know. As far as HO are concerned, they are providing a service that works, same for SKY. I would say the onus is on SKY to work out why certain ISP(s) are having difficulty with streaming, not the other way round.
Message posted on 30 Jan 2025 04:27 PM
The Sky Stream Puck is not fit for purpose!
I have this and other problems on 500mb Virgin Media...
I have 2 pucks, one on ethernet the other wifi...
Low Spec and designed by people who clearly have no experience with PVR's etc.
Message posted on 30 Jan 2025 04:36 PM
Fine here on my 63Mbps FTTC connection.
Message posted on 30 Jan 2025 04:47 PM
Hi, so you never get buffering issues with ITVX, Netflix or Prime.
I do too frequently, but when I watch on the app on the TV or on a Roku, no such problems arise and the picture is much more smooth.
I understand that some people have said that reducing from 4K to HD resolve the problem, but that then begs the question why am I paying for 4K.
Message posted on 30 Jan 2025 04:54 PM
I occasionally see buffering on my Panasonic TV's ( not my Glass) built-in Prime app, but no, not on my Puck or Glass.
Message posted on 30 Jan 2025 05:30 PM
Strange.....
