Discussion topic: There is a technical fault with this programme. Please try again later.
Message posted on 07 Apr 2024 09:41 AM
Just sat down to watch the Paris-Roubaix on Sky Sports 1, with my SKY Stream. And i get the usual "There is a technical fault with this programme. Please try again later." I am literally shaking with rage. I can't believe I pay SKY £79 a month to supply this. I try putting in to standby and removing power, sometimes for quite a while, but it's no good. If SKY can't provide the service they promised, i need to get out of this contract. Anyone got any experience with this?
Message posted on 07 Apr 2024 09:55 AM
Re: There is a technical fault with this programme. Please try again later.
@Robert0072 How is the puck connecting to the hub?
Have you checked the network settings within the puck menu?
Settings --> Startup and standby--> Network standby mode--> On.
Message posted on 07 Apr 2024 10:01 AM
Hello, and thanks for your reply. It is connected with ethernet. Networked standby mode was off. I have put it on. Do you think this will help, and if so why?
Message posted on 07 Apr 2024 10:03 AM
@Robert0072 I would hope this would resolve the issue, I have my puck connected to ethernet and network standby to on.
What seems to happen when network standby is off os the puck stops looking at your network when in standby mode and once put it out of standby mode doesn't pick up the network again.
Message posted on 07 Apr 2024 10:06 AM
Wouldn't that mean it would affect all channels?
Message posted on 07 Apr 2024 10:13 AM
@Robert0072 It can be quite random, the new settings should help.
Message posted on 07 Apr 2024 10:19 AM
Thanks for the help. I'll try and keep you and the forum updated.
Message posted on 07 Apr 2024 10:30 AM
Having Network standby off, does seem to to put in a small delay at puck startup.
Best is to set Network standby to ON.
But also, if you are using ethernet, to also turn wifi OFF in settings, as the puck can try to default to a wifi connection occasionally, whether you have one setup or not.
If you make that wifi setting change, do a power reset of the puck, by removing the puck power plug or switch off at the socket for about 30 seconds.
Message posted on 07 Apr 2024 10:36 AM
OK thanks. When i changed to ethernet, switching wifi off was the first thing i did, for this reason.
Message posted on 11 Apr 2024 04:51 PM
This hasn't helped. The problem persists. I was getting the message with Sky News and BBC News. I standby'd and power cycled. They came back after that.
Message posted on 12 Apr 2024 03:45 PM
Happening again. I just tried removing ethernet to see if the fault happens with WiFi. It does.
Message posted on 06 Jun 2024 05:22 PM
This issue persists. Does anyone have an answer?
Message posted on 15 Jun 2024 05:31 PM
It wouldn't be so bad if it happened with random shows, but it always (and only) happens with exactly the show i want to watch. It's probably the most infuriating thing I have ever encountered. Can anyone offer any help/suggestions? Is there any way of getting any help from SKY?
Message posted on 15 Jun 2024 06:23 PM
@Robert0072 wrote:It wouldn't be so bad if it happened with random shows, but it always (and only) happens with exactly the show i want to watch. It's probably the most infuriating thing I have ever encountered. Can anyone offer any help/suggestions? Is there any way of getting any help from SKY?
Pull the physical plug from the mains for 10 minutes
Message posted on 16 Jun 2024 11:01 AM
I've tried this. And the router. No use, still does it. I'm trying to continue watching "My Brilliant Friend, SKY Atlantic". I simply can't, no matter what i try.
