Discussion topic: Technical fault
This message was authored by: Shaz102
Technical fault
No programs says technical failt
This message was authored by: Brill+Gill
Re: Technical fault
Posted by a Sky employee
Hi @Shaz102, I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Re: Technical fault
Hi @Shaz102 and welcome to the forum.  Try rebooting the puck by going into settings  > system management >resets & updates > restart device.  It will take a couple of minutes to reboot and you will have a blank screen for a period before the Sky logo appears.
If the technical fault prevents you from following this procedure then simply unplug the puck from the wall socket for a couple of minutes and then plug it back in again.
