Discussion topic: Technical fault
This message was authored by: Flower01
Technical fault
I have a sky stream pick and there is a technical fault. Please try again message. It's not my broadband as other channels work - Netflix, 4OD etc. Though for argument sake I have reset the broadband and the puck, alas the technical message remains. What next?
I have zero desire to call Sky (who apparently are really busy) and sit waiting for someone to tell me to reset like I already have. Questioning why I'm paying £75 per month and I'm not able to watch F1, it's live, I'm missing it and I'm annoyed!
Re: Technical fault
@Flower01  Your post has been moved from the Sky+ Board to the correct board for Sky Stream.
This message was authored by: Jporch316
Re: Technical fault
Hi
how fast is your wifi ? You can check this on the native Netflix app by going to get help and selecting check my network
stream needs at least 25mbs if not 30 consistently
