Discussion topic: Technical fault onscreen
This message was authored by: SandraS
Message posted on 04 Dec 2024 06:04 PM
Have this message on screen
There is a technical fault on this channel. Please try later.
its on all my BBC, ITV, 4 and 5 can anyone help
thanks
Find out more
Message posted on 04 Dec 2024 06:27 PM
Re: Technical fault onscreen
Hi @SandraS
Try restarting your puck in the first instance. Go Settings > System Management > Resets & updates > Restart device.
MikeAlanR
Message posted on 04 Dec 2024 06:37 PM
Thank you this worked. But why does this happen it's the second time in so many weeks.
