Discussion topic: Technical Fault
This message was authored by: ELJAY9873
Technical Fault
My sky tv is telling me there is a technical fault and to try again later. I have tried a few different channels and get the same notification. All lights are in and green, no issues with that so... What is the problem?
This message was authored by: nell598lukas
Re: Technical Fault
Hello @ELJAY9873,
If all lights are green but every channel shows a technical fault, it’s likely a signal or service outage rather than your box. Best step is to reboot the Sky box and check service status — if the fault persists, contact Sky support to confirm if there’s a wider issue in your area.
Best Regards,
Nell Lucas
