Discussion topic: Intermittent sound and picture problems
This message was authored by: GeneBeck
The sound on my sky puck cuts out for around a second every minute or so and the puck will re start to home page now and again I have tried unplugging the hub, The hub isnt blocked my wifi is good and my broadband speeds are above 500mps
Re: Intermittent sound and picture problems
@GeneBeck Have you tried hardwire with Ethernet from the Puck to the sky Hub incase it is a wireless wifi issue!
This message was authored by: Stephen+Mourton
@GeneBeck  The suggestion from @JimM1 is a good one.  If like me it's not possible to connect via an Ethernet cable without moving  equipment into a position you could not permanently have ( in my case it would require a wire across the middle of the room) just try it temporarily then if it solves your problem then you know it is down to your setup and not Skys fault, obviously if you still have a problem you need to contact Sky.  I hope that helps.
