1
This discussion topic has been answered Discussion topic: TV volumn with sky stream remote
This message was authored by: Paul43
Setting up Sky Stream today I could not hear any sound when asked try changing the volumn so gave up. Later realised I was nor set up correctly with my sounbar. How can I redo that part of the set up?
This message was authored by: Fothergill1 Answer
Re: TV volumn with sky stream remote
@Paul43 You will be able to setup the remote to control your TV and soundbar (if compatible) by goind into Settings > Connected devices > Remote.  You will find an option there for soundbars.
