Discussion topic: TUYA smart infrared and Sky stream
This message was authored by: perrosno
I am trying to configure a TUYA smart infrared device to operate my Sky Stream.
I can create a custom remote and teach it the Sky Stream infrared signals from my existing remote but this results in a rather primitive looking control pad.
I was hoping to find a pre-configured remote in the TUYA library but have been unable to identify the correct one (if it exists).
Has anyone done this? Can you point me to the correct template?
Many thanks.
Re: TUYA smart infrared and Sky stream
@perrosno never seen anything on the forum but is there a Sky Q or Sky +HD set up you can alter? A Sky Q remote can control most puck functions.
Avatar for perrosno
Level 2 icon
Great tip. I will look into that.
Thank you.
Avatar for perrosno
Level 2 icon
The solution seems to be to choose a remote with a similar layout and then reprogram the buttons using the learning feature.
It's a bit tricky because the Sky Stream remote outputs infrared just by moving it (ie. not even pressing a button).
