Discussion topic: TNT Sports
Message posted on 05 Jan 2026 05:06 PM
TNT Sports
Hi
Has anyone transferred from Sky Q to Sky Stream with a TNT Sports subscription with BT
If so was it seamless and TNT Sports was there from the start
Message posted on 05 Jan 2026 07:54 PM
Re: TNT Sports
If you want TNT via the stream epg, you need to subscribe via Sky or have a standalone subscription and use the Discovery+ app...
Message posted on 05 Jan 2026 08:02 PM
Re: TNT Sports
You can't have TNT sports though bt on stream that is only available on skyb Q box. TNT sports is only available on stream if add to your Sky package. So if you want TNT sport on stream you need to cancel with bt and then contact Sky to add it your package
Message posted on 05 Jan 2026 08:22 PM
Re: TNT Sports
I got this from the Sky Stream FAQs
"To watch TNT Sports on Sky Stream, you need to take TNT Sports with Sky, unless you’re switching from Sky+/Q and already have a TNT Sports subscription with BT, then you can carry on using your BT subscription."
I have spoken to Sky who intimated it was okay from their point of view
Just a bit concerned if it will work smoothly if I go ahead
