Discussion topic: Stream remote
Message posted on 20 Oct 2024 11:25 AM
Stream remote
I have stream and two pucks. One for downstairs and one for my bedroom. Not sure how it happened but both seem to work with my tv downstairs but can't set up in my bedroom. Have tried all the dual button pressing to reset to no avail. Back light on downstairs but dead in bedroom! Help!!!!!
Message posted on 20 Oct 2024 08:58 PM
Re: Stream remote
@Kevhitch You have put as your heading 'Stream Remote' but it sounds like you are having problems with your puck. Could you please confirm which it is? Thanks.
Message posted on 20 Oct 2024 09:20 PM
Re: Stream remote
@Kevhitch wrote:I have stream and two pucks. One for downstairs and one for my bedroom. Not sure how it happened but both seem to work with my tv downstairs but can't set up in my bedroom. Have tried all the dual button pressing to reset to no avail. Back light on downstairs but dead in bedroom! Help!!!!!
Hi
try pulling the plug s on both .... then just turn on the one upstairs and do the below
The remote can be reset and paired again following these steps;
- Press and hold 7 and 9 together on your Sky remote for three seconds.
- Press and hold 4 and 6 together for three seconds.
- Press and hold 1 and 3 together for three seconds and follow the on-screen instructions.
