7
Discussion topic: Stream puck says out of range??
This message was authored by Rob+AB This message was authored by: Rob+AB
Hi. Have just moved to sky glass and stream from Sky q. Puck works fine on one tv but when trying it on an older 1080p tv in bedroom I just get an  out of range message on the screen. Any ideas? Thanks
This message was authored by SlenderRobert This message was authored by: SlenderRobert Answer
Re: Stream puck says out of range??
@Rob+AB wrote:
Thanks all
Yes it is not the wi-fi as I got the out of range message before I could even configure the wi-fi.
It appears the TV doesn't like the input. Question is what can be done to fix it?
Any ideas?
Rob
Using your Stream puck remote press HOME, followed by the numbers 1, 0, 8, 0 and press HOME again. That should reset the video output to the native 1080i.
This message was authored by Tim+Adams This message was authored by: Tim+Adams
Hi @Rob+AB
What picture mode is the Stream in? Is it possible you've got it set to 2160p for the TV that works?
Thanks,
Tim
Sky Glass with Sky Live, Sky Stream & Sky Protect - FTTP 2Gbps
Are you sure that's a message from the Stream puck and not your TV or some other device?
How fast is your broadband in the bedroom? It needs to be fast and stable for Stream to have any chance of functioning.
As @Tim+Adams indicates, 'out of range' in this context almost certainly relates to video output resolution rather than WiFi, although it's undoubtedly confusing (and inherited from the days of CRT)
Rob+AB
Thanks all
Any ideas?
Rob
@Rob+AB wrote:
Thanks all
Any ideas?
Rob
This message was authored by Jporch316 This message was authored by: Jporch316
@Rob+AB
Plug it back into the original tv and change the setting in picture to 1080 only
43inch and 55 inch Sky Glass & 3 Pucks on virgin media M350 hub 5x. 4 x sky mobile sims. Pretend guitar aficionado .. rock on!
Rob+AB
Thanks Slender Rob
I turned on the puck ready to follow your advice
As it booted up the screen showed 1080i and the puck started working fine
Seems strange but I'm happy it is now working.
Thanks for your help
Cheers
Rob
