Discussion topic: Stream picture freeze for seconnd - issue ongoing for months
Message posted on 25 Aug 2026 10:26 PM
Issue ongoing for months been reported and engineer recommended an new puck - but that was refused so made a complaint as no satifactory conclusion . Screen still freezing and starting g again after a couple of seconds
Message posted on 26 Aug 2026 09:19 AM
Re: Stream picture freeze for seconnd - issue ongoing for months
Billyjo44332211
Welcome to the forum
We are all fellow customers on here like yourself
Two things can you connect the puck with an ethernet cable it is more stable than WiFi also going in to the apps on the home page open Netflix go to help and run check your network.this will tell you what speed the puck is getting. Remember sky recommend that to watch hd channels you need a minimum of 25mps and to watch uhd channels you need a minimum of 35mps and also the more devices that you have connected to the Internet the weaker the signal is to each one and also if you live in an old house with brick interior walls this can effect the signal to your devices
