Discussion topic: Stream keeps freezing
Message posted on 14 Oct 2025 07:18 PM
Message posted on 14 Oct 2025 07:50 PM
Re: Stream keeps freezing
Hi @Lyn70 and welcome to the forum.
One of the main reasons for freezing (or stuttering) is the quality and speed of the Wi-Fi signal being received at the TV/puck and not that being received at the router. This can be checked with the Netflix App (Get help > Check network) and is often much less than you might expect. The minimum speeds recommended by Sky are as follows:
HD = 25mbps
UHD = 30mbps
HD + 1 puck = 30mbps
UHD + 1 puck = 35mbps
These speeds assume there is nothing else in your home using up your WiFi bandwidth.
If your speed at the TV is borderline try connecting via Ethernet cable. If this is not practical you can use powerline adapters (about £40 at Amazon). Note the Ethernet port on the Glass TV (& pucks) only supports 100mbps so don't waste money on the more expensive 1gb powerline adapters
