29 Oct 2024 07:23 PM
Is there something wrong with Sky Stream? For the last couple of days it is struggling to stream live tv with pictures going black and message saying waiting for program to load. I do not have any issues with my full fibre connection and have had the issue on WiFi and Ethernet. I see other posts about this which indicates there does seem to be a problem somewhere. I can stream apps from my tv and apple box with no issues.
30 Oct 2024 06:58 PM
Issue seems to be resolved since earlier this afternoon.
29 Oct 2024 07:28 PM
Sky stream can provide variable performance even with good WiFi speeds. How are you connecting to the broadband ? Try Ethernet connection. I would also recommend turning the box off and on for a couple of mins. If the problems persist contact sky
29 Oct 2024 07:48 PM
Tried all of that, it didn't make any difference. I have had stream for 2 years and haven't had any issues until recently.
30 Oct 2024 08:04 AM
@Nesslad wrote:Is there something wrong with Sky Stream? For the last couple of days it is struggling to stream live tv with pictures going black and message saying waiting for program to load. I do not have any issues with my full fibre connection and have had the issue on WiFi and Ethernet. I see other posts about this which indicates there does seem to be a problem somewhere. I can stream apps from my tv and apple box with no issues.
When you tried Ethernet connection did you turn WiFi off in settings?
30 Oct 2024 10:15 AM
Yeah I did. Same issues occurring again today!
30 Oct 2024 10:22 AM
Posted by a Superuser, not a Sky employee. Find out moreJust to be certain that something has not changed on your local network, like other new devices or some kind of new interference.
Can you do a network speed test on your Puck.
Launch Netflix on your puck (you do not need to be logged into it, if you do not use netflix) and scroll down the left menu to Get help.
Choose Check Network.
Would suggest running the test a few times, say a few minutes between tests.
What is your speed?
Try a restart on your Sky Stream puck from the settings;
Go to Settings>Systems Management>Resets & Updates
Select Restart device
Your Sky Stream puck will perform a reboot. It will take a few minutes to complete
30 Oct 2024 10:24 AM
Hi Nesslad,
I am having exactly the same problems.
Screen going blank, unable to load programme. I am resetting the password to get going again.
Mine does appear to happen at the same time most evenings. Very frustrating and can not beleive Sky have not identified this problem and at least sent out a message that they are working on it.
04 Feb 2025 09:26 PM
I've had this issue since Sunday, rebooted puck and router, I use ethernet as standard, only affects one puck. Do Sky have a fix?
