Discussion topic: Stream, SONOS ARC and LG OLED
Message posted on 08 Jul 2024 04:45 PM
Im sorry to ask but is this something others are having ? Randomly when i switch between TV and apps there is no sound, its almost as if the TV or stream cant 'see' the soundbar - using eARC on passthrough from the TV as I did with my old Q setup - only way round it is to either go into settings and manually change the audio source or switch between apps back and forth - ive tried setting it on Auto, DD plus DD and passthrough etc. - it has periods where it settles down but atm its beyond a joke?
any clues, advice or guidance would be greatfully appreciated - im not sure if its SKY's LG's or SONOS's fault
Message posted on 08 Jul 2024 05:03 PM
Re: Stream, SONOS ARC and LG OLED
Have you tried changing the audio mode on the LG TV away from ARC and back?
Message posted on 08 Jul 2024 05:17 PM
I'll give it a try ans see if it sorts - i have everthibg on smartplugs so it all turns completely off during thr night to save power and wondered if it was that but its only started with stream - i'll give it a try - appreciate the reply 😄👍
Message posted on 08 Jul 2024 05:29 PM
LG TVs can get confused by how they are switched off😟
