1
This discussion topic has been answered Discussion topic: Stream Puk cable
This message was authored by: 67216762
Stream Puk cable
The plug on the stream puk is rather large and hard to hide behind a wall mounted TV I'm thinking of replacing the plug with a normal standard 3 pin plug. However I realise there are only two wires a white one and a naked copper wire one. Is it safe to transfer this to a 3 pin plug or can an alternative plug be purchased that's less obtrusive.  Thanks.
This message was authored by: mikealanr Answer
Re: Stream Puk cable
Hi @67216762
The plug that comes with stream is the only one available from sky and should be the only one used to maintain the warranty as per the t&C's you've agreed to. It definitely would not be recommended to wire your own plug.
Could you not use an extension lead relocate the sky plug?
MikeAlanR
Hi @67216762
MikeAlanR
