Discussion topic: Stream Puck not connecting via ethernet
This message was authored by: EvaDeva
My Puck hasn't been able to connect for sometime. It will work on WiFi but not via ethernet. It searches for an IP and can't find one so stops there. I have tried 3 different cables and no difference. The TV works via ethernet and I have no problems with that, just the puck.  Any ideas to get me connected?
This message was authored by: Jporch316
Re: Stream Puck not connecting via ethernet
Is there an issue with your wifi connection? If not I would leave it on wifi
You could also try unplugging your device then rebooting your router (probably best to totally power it off for a few minutes ) the. Powering on your router the. Powering on your device
also worth trying a different ethernet port on your router
Who is your ISP?
Avatar for EvaDeva
I have tried that, thank you, but still not working.
Avatar for EvaDeva
it is Sky
Avatar for EvaDeva
The WiFi is fine - I don't use WiFi in my house, only ethernet.
Have you reported the issue to Sky?
