Discussion topic: Stream - Nothing will load
This message was authored by: TDE
Nothing will load, presume weather - anybody else having issues
Re: Stream - Nothing will load
@TDE   Unless your broadband is down weather won't affect stream as all channels are delivered via broadband.
Have you tried a reboot of your stream puck?
Avatar for TDE
Thanks for your reply
Broadband is fine - I'll reboot it all tomorrow - given up with it tonight 😂
The first thing to try is a Settings RESTART ... that would've only taken a few minutes😉
Would suggest trying a restart of your Sky Stream box
Go to Settings>Systems Management>Resets & Updates
Select Restart device
Your Sky Stream puck will perform a reboot. It will take a few minutes to complete
